KnuKoncepts KLMX 1/0
If im going from my engine to my toolbox, then into the cab of my truck form the back (into the vents) into a distribution block there is no way I need 44 ft. I took it down to about 25. My Price is now 210 which I can roll with. Ill do my big 3 in grey to keep the wires seperate.
man kicker hyperflex 0 gauge spool is cheaper than the price u got there. I got mine installed with those The kicker hpyer is REALLY flex . Knu used the same rubber for wires just as kicker does so their wires are flexible like kicker.
i have KLM and KLMX running in my CRX. It goes from the back to the battery just fine and the alt to the battery even better. IF you buy it you wont be disappointed except for trying to fit a standard 1/0 ring on it. I did find the KLMX a lot more flexible than KLM. What kind of car are you running for it to make very tight turns?
Just bought a shit ton of klmx, and its a lot nicer to work with than the klm was, looks exactly the same tho
As for the issue of "stressing the wire's materials"... cmon guys, it's WIRE. It's not going to break if u bend it too far //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I never really saw the point of buying 1/0 that costs twice as much. I've never had any issues with any wire i've ever used not being able to make tight enough turns.
Have you tried putting this cable in a fuse or distribution block? I would like to know if it fits in a 1/0 opening or if infact I would have to use 2/0.
It will be in a 05 f150. I will run these from my engine bay-underneath my cab and into my toolbox. To get there I would ned to run the 1/0 inbetween the cab of my truck and my bed which is like 1 inch room. The problem I would run into is making the turn at the top of the bed to enter the toolbox in the back so I can connect it to my spare battery.
Then I have to go from my toolbox battery back inbetween the cab and bed of truck into the vents that are on the rear of my cab and make that turn into there. I feel a non flexible cable would own me right here.
haha my cart wasnt just the wires. they were 1.60 or 1.75 a ft so I only paid about 44 bucks for each 25 foot run. I should be ordering those today, and then my rca's from monoprice.com
Black Truck 10
Black Truck 10
Houston, Tx
Black Truck 10
