knu konceptz distrobution block not working, did i set it up right?
Cruzer
i have this distro block
Car Audio Wire
i have 4 gauge going into the input side, then on the output side i have 4 gauge going to my aq1200d, then 8 gauge going to a kenwood 2 channel amp.
the aq1200d was working fine no problems, i just put the distro block in cut the 4 gauge i had going to it and put the block in between the amp and the wire. now its not coming on, the kenwood doesnt come on.
im not sure where the fuses go, or how that works. but that should not affect it from working.
i have not ran a ground from the distro block so the digital voltage display works, but does it need a ground in general to work period? or it should be working just not the digital display?
any help, suggestions, etc. are appreciated
If you're not sure what you are doing, you need to get some help from somebody so you don't burn your car down, or fry your equipment. If you know somebody local, give them a call, so they can come and take a look at what you have done.
Cruzer
Cruzer
smyrna, tn
Cruzer
