knu klmx power wire any good?
Its good stuff for the price. Just overkill when using KLM wire, its 80% aluminum, so it doesnt conduct as well as copper, meaning less amperage potential through the wire, and more of a voltage drop over the wire run?
the klmx is decent wire yes. If you have the money to get the kolossus, I would definitely get the kolossus. The CCA wire will not be able to handle as much current. I think the KLMX can handle 250 amps or so. If that is more than the fuses on your amp you should be fine
I Like Waffle
North Carolina
BushJ311
