Know about the signs on DVD discs
  • Thread starter jane1043
  • Replies 0
  • Views 330
jane1043
12
fg
Buying DVD-Video film is not as simple as buying VCD disc or Cassette, as each DVD disc contains various
icons, pointing out different Specifications. If you muddled to purchase some DVD film, maybe it can not play
on DVD player. So it is necessary for you to learn about the common signs on the DVD disc.
1. Sign for DVD Video
The standard DVD-Video laser disc: on each pack of DVD laser disc, you must have seen the sign, showing the
content on the DVD disc is in line with DVD-Video standard audio-visual materials and all the function
Compliance with the definition of specifications. As long as you see the sign, you will be sure that it is a
DVD-Video laser video-audio disc, which can play on DVD players.
2. DOLBY DIGITAL Dolby
The sign shows that the audio signal on the disc has used AC-3 encoder processing, which allows you to enjoy
the digital sound effects. DTS, MPEG2 etc are similar with it.
3. NTSC OR PAL
Video system signs: Generally speaking, video system and the region Restrictions usually are combined
together. However, under some circumstances, they will be separate. Commonly, there are two video system
signs, one of which, NTSC is the video output system for USA. Europe and mainland of China use PAL system. In
addition, beside these two signs there are the appropriate region restrictions. “All” stands for unlocking
region. The number presents the region where you can enjoy this film.
4. Subtitle
Multi-subtitle playback: the icon shows that it offers various different subtitles on the disc. The figure
among them says out the number. However, some of DVD discs don’t use this kind of subtitle, which requires
you to take notes of the character of outside pack. After this, you can make sure whether there is the
subtitle that you what to see.
5. Aspect ratio
Video format: If it is shown as 4:3, which says out the image has been processed into 4:3, which is fit for
playback on the traditional TV set. If 16:9 is shown on the outside package, while you want the playback on
TV set with 4:3, you have to watch it as Letterbox or Pan & Scan mode. Then the quality may be affected
slightly.
6. RESTRICTED
The film classification: copyrighted films mostly are divided by the Film classification system of USA, which
divided the film as G, PG, PG-13, R, NC-17 etc.
Without a doubt, these signs are very useful. Of course, when choosing DVD disc, you should pay attention to
the reality of the coverage. In fact, the Pirated films are no more the content of the disc. For example,
some DVDs are duplicated as VCD. This won’t keep in line with the original one. But the outside package
still uses the introduction of the authentic. These should be taken notes of.
More dvd ripper tools may be used:http://www.pavtube.com/dvd_ripper
jane1043
jane1043
fg
jane1043
