First look up what the concept of statistical significance means. Having not read the paper, I do not even argue here that the paper is wrong in any way. I do not question their results, although seeing that it's only an unpublished paper, only the test of time and peer review will tell whether their results are even correct. I am just pointing out that the results do not say anything conclusive. Look at the abstract. Like I pointed out, their findings don't seem to prove anything.
I am sorry man, but if you have read through "the gobbledygook" and you're still convinced that it constitutes a proof that the stimulus didn't work, clearly there is no point to argue with you. You post links that clearly do not 'prove' anything, then proceed to use that as a basis to accuse others of liberal bias, lying, etc. If you want to believe what you believe, then keep doing so. I don't want to waste my braincells to continue to argue with the equivalent of stone rock.
