Sold Kinetik HC16V
slam
Kinetik HC16V
This is the 3 post 16v 12v battery. Run ur car and 16v system or just ur 16v system
150 shipped
I have just the charger here too:
http://www.caraudio.com/forum/showthread.php?t=437699
Also
Here are the specs from Kinetik: thanx
Kinetik HC16V Power Cell
With our dual post design for running at 12 volt or 16 volt, this bad boy has what it takes to run your amplifiers and equipment at peak performance. For high end systems, running multiple HC16V Power Cells will give you that edge you need to win.
Specifications
* Weight: 54lbs
* Ah: 62
* Dimensions: 10"x6.5"x8.2"
* Suggested Retail: $349.99
Common Specifications
* AGM Technology
* Sealed Non-Spillable Design
* Mount In Any Position
* Ultra Low ESR
* More Plates For Stronger Energy Density
* Higher Voltage Under Load
* Tightly Packed Cells
* Superior Heat & Vibration Resistance
slam
slam
fort worth, tx
slam
