Killer Capacitor
I don't think a capacitor rated at 20v or less will be an electrocution danger. You don't want to wear dangly jewelry around it, but it's not enough voltage to send significant current through your heart, no matter how many farads it is. Electrocution danger starts around 30v.
It's not the voltage that kills you, it's the current - like you mentioned. Do you not think a car battery can kill you, even though it's only 12VDC? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
You can get hit with 4500V, but if there's only a few microamps of current, you'll survive...
even small caps (small enough to fit into stupid kids prank pens) hurt quite a bit.
im sure a 1F capacitor can deliver quite a big shock to a person.
not sure about the ablility to kill someone, but if it doesnt kill itll hurt ALOT
Not except under some extreme circumstances. Yes, current is the killer, but current doesn't happen without enough electrical potential (voltage) to create the current flow. The human body has enough resistance that it takes a higher voltage to generate enough current to be lethal. Of course, there are variables that affect the resistance of the human body; sweaty skin, jewelry, and so on. But the voltage level generally accepted to be unsafe is about 30 volts. I've never seen or heard of a case where someone was electrocuted--killed--by a 12v car battery. I bet it could be done with a high power amp playing a 60hz tone, though!
Check out this link for more information:
http://www.allaboutcircuits.com/vol_1/chpt_3/4.html
x2
Alpine2005
CARROZZERIA
Alpine2005
CA
Cbass
