Sold Killer 165 amp alternator
turboaz
(1) rebuilt Prestolite A0017706AA extreme duty alternator. Does over 100 amps at an IDLE. 145 amp Lt1 alt doesn't even come close to the true power output of this beast. Made for ambulances and busses, so the parts are twice as strong and welded, not soldered together.The last alternator You"ll ever have to put on Your car or truck. No more low voltage or current problems.with just about any stereo.(might need to swap out the pulley and modify the bracket and run a 1/0 cable to the battery) Over $500 new. $200 . Paul 480-221-9572
Im the mediator here and Im sure that when you wrote any system he was like wtf. LIke for my instance I need 2 300 amp alts, running just 1 under the hood Powermaster D5100 and 3 NSB 90's in the back since I have Digital Designs m4a and Z-se ( alternate), putting out around 7000-8400 with easy at .75 ohm at a low 13, at 14.4 its more like 8400-10000 watts . Good alt, but not for everyone
bump if you have a system under 2000 watts perhaps.
There ya go
Daniel
Im the mediator here and Im sure that when you wrote any system he was like wtf. LIke for my instance I need 2 300 amp alts, running just 1 under the hood Powermaster D5100 and 3 NSB 90's in the back since I have Digital Designs m4a and Z-se ( alternate), putting out around 7000-8400 with easy at .75 ohm at a low 13, at 14.4 its more like 8400-10000 watts . Good alt, but not for everyonebump if you have a system under 2000 watts perhaps.
There ya go
Daniel
Yea it would work okay. But if it was my moneys I'd spend a bit more for a better one.
There ya go
Daniel
turboaz
turboaz
Phoenix, Az.
on1wheel01
