Kickers.
10's will be fine, ported with 400/450 watts to each...dual 2's, look at the Kicker KX6001 or newer ZX7501
If i need 400-450 watts to each then how would a 600 watt amp like the kicker KX6001 be good for these subs wouldn't i need like a 1200 watt amp mayb?
no, the KX6001, some have been tested and do 700 watts, so 350 to each. Just because a woofer can handle more, doesn't mean it has too..
Woofer size has NOTHING to do with what type of music you listen to.
It can in that the specs on a 10 do not allow it to get as low with relative output efficiency as say a 12. There are more rap songs that I can think of that go LOOWW than do rock songs, which might be the reason for that assumption?
Hugebass
Hugebass
Milton Florida
Tirefryr
