Kicker zx850.4 good amp?
gizmo206
23
NL
Hello,
Can some one tell me if this is a good amp for my bostons pro60 speakers?
I'd like to use 2 canals from the amp for feeding my bostons and 2 for my sub.
Later on the 2 from the sub using for 2 extra speaker and a mono amp extra for my sub.
Greetz
Gizmo206
Specs:
Power rating:
175 Watts x 4 RMS 4 ohms CEA rating
215 Watts x 4 RMS @ 2 ohms
425 Watts RMS x 2 @ 4 ohms
Kicker EQ boost up to 18db
20hz - 200khz frequency response
250mv - 10v input sensitivity
>95db or better signal to noise ratio
Selectable low pass crossover
Subsonic filter @ 25 hz 12 db per octave
12 DB per octave 50 – 200hz adjustable crossover
High pass low pass or all pass
Soft start circuit
Protection circuit
Dimentions:23 1/4"L x 2.1/8"H x 9 -5/8 "W
Hello,
Greetz
Gizmo206
Specs:
Power rating:
Soft start circuit
Protection circuit
if they have seperate filters and seperate gains for the front and rear channels then yes you can run subs off of it as well. my opinion...run a seperate amp to teh subs
hmm
but the kicker amps are fine????
i'm still discussing to buy the JL 450/4 or these kicker.
I don't know if I would like to have rear speakers when having an other amp....
by the kicker i still have that option by the jl 450/4.
anyone sugestion?????
kicker makes a quality product that is underratted and comes with a birthsheet for proof. you will get more wattage than you pay for, and you will get a quality product, no ifs, and, or buts.
although jl makes quality products as well, they are much like nike and overcharge for their name. period. get whichever one you like better and fits your application best. you wont regret either, thats my personal promise.
I currently have this amp running my entire system and I absolutely love it. I'm running all 4 in car (Infinity) speakers off the first 2 channels and channels 3 & 4 are running a single 12" sub. This amplifier by far and away has to be one of best amps I have ever personally owned. You will not be disappointed at all.
gizmo206
gizmo206
NL
Goldtaz1
