dBoy
My Kicker 700.5 sub amp (the Class D amp ONLY) will regularly shut down at higher vol levels. The 4-ch A/B amp side powering the 4 door speakers is fine, does not shut down, just the sub amp - sub amp rated 420 RMS at 2 ohms. Any thoughts on why this is happening? It's driving me nuts.
Using a single 10" Kappa sub rated 350 RMS in a sealed 0.75 cu ft enclosure, set to 2 ohms (the sub has a 2ohm/4ohm switch). Had amp tuned/o-scoped at an audio shop. Gain on the sub amp is 10.5/11 (almost 100%) - the sub had some trouble keeping up at tuning so I built a much better box for it but havent changed the gains yet. Amp Bass Boost is about 40%, used new Kicker recommended Kicker 4 ga wiring kit, ground drilled/paint stripped thru chassis within 12" of amp, (system has zero noise/alt whine, it's dead silent).
Amp is well ventilated, sitting off floor on 1" end blocks w/4" space above and clear all around. GMC Yukon with stock alternator/battery/elec system excpet for the 4 ga amp wiring.
It's odd to me that only the sub amp side cuts out, any thoughts???
Thanks!
Thanks!
