Roccaus
Rockin Man
can a kicker zx2500x1 be run @.5 ohm, if so whats the life span with doing so
Wire it to 1.3 ohms, with impedance rise, you'll prolly get to 2 ohms, if not close.ok for one, your 3 d2 ohm subs can only be wired to 1.3 ohms or 3 ohms. so if you set your gains right you can get about 800 watts rms to each sub.
big 3 and a second batt in the trunk.here is the system i hav in a 85 chevy caprice, i hav 3 kicker 15" l7's, kicker zx2500,kicker 0 guage all the way thru,kicker sx900x4 wit d kicker sxrc, i have 4 5-way pioneer 6x9's in d window' pioneer 4-way6.5's in each door, 2 4-way 4x6's in dash with a premier 980bt cd player, also i'm running 1 battery under the hood and its a kinetic 2400, also i have 4 kicker tweeters, any suggestions to the system
