kicker zx2500.1
  • 4
kc313
mn
Used on 2 havoc 18s. Never operated under 2ohms. 8/10 with minor scratches. Bass knob not included
$375 plus shipping
UPS insured
would you be scared to run this at 1 ohm?
I probably would give it a shot if i had the need for a 1 ohm amp but i wouldnt buy it expecting it to work
482
971
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
kc313
kc313
mn
kc313
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
