Sold Kicker XPL 12 / KX400.1 / 2 15s "ABC" Box
RidnClean
Love 4 Money
selling cause i may be moving to 18s in the expo.
box is all birch too! so its light as a mofo.
what exactly is an ABC box:
Aperiodic Bi-Chamber
Dual-Chamber ported systems are systems that have the following physical characteristics:
The system consists of two separate volumes, connected together by a port.
Each volume is vented to the outside by a port.
All ports are typically of the same size and length.
One volume, typically the larger one, contains the driver.
The primary advantage of the dual-chamber system over a simple ported system using the same driver is a further reduction in driver excursion, caused by the addition of a second port resonance within the passband of the system. This reduction in excursion results in increased power handling within the system's passband, making this type of system particularly suitable for use for drivers with low Xmax. However, because of the additional chamber and venting requirements, this system is considerably more difficult to design and build when compared to a simple vented system.
from diy subpage
specs:
7.5cubes total tuned to 32/46Hz
38.5 wide
21.25 tall
37.5 deep
box is paint black with white ports
price is $100
local sale only.
pics:
RidnClean
Love 4 Money
RidnClean
Washington
RidnClean
