Kicker SX900.2 Help
09Alti
Hi Guys,
Last night I installed my *new* (not brand new, but it was still in the box, sealed in the plastic, never used, etc...) Kicker SX900.2 and am not getting any sound from it. From the point we turned it on there has been nothing. I checked the Sick Bay and am getting 2 errors. 1=Overload 2=Hi-Volt
The max voltage this thing has seen so far is 14.9v and the lowest was 12.4v (when the car wasn't running and we were testing)
So the Overload error isn't in the book, and I don't know about the Hi-Volt message, it doesnt seem like 14.6v would be too high for this amp.
Anyone have input as to what the problem would be?
Background: I'm using this SX900.2 bridged at 4-ohms running to 2 Kicker CVR 12's at 4-ohms. I also have an Orion Cobalt running my Kicker SS65.2 components, and this part of the setup works fine. I pulled the RCAs from the Orion and plugged into the SX and still got no output.
Any help is appreciated.
Thanks
are your voice coils on each sub wired serial or parallel? if parallel you are giving the amp a 1 ohm load in bridge and looking at the specs for your amp on crutchfield, it says 4 ohm is the minimum for bridge mode.
09Alti
09Alti
Charleston, SC
DukeNut
