I have a used Kicker sx1250.1, number two of four I owned. Someone here bought number one, hope he likes it. Anyhoo It works great has light sscrathes from the end caps, which I no longer have neither do I have the remote. I am asking $250 plus actual shipping, if you live in the Chicago/burbs we can meet somewhere for pickup. Great amp you will not be disappointed. I have the original box but no manual, remote or cables. This is OBO so throw up some offers. PP is accepted but please inlcude all applicable fees.. Polo..
24-bit audio resolution
44.1kHz sampling frequency
0.7 millisecond response time allows additional, non-digital amplifiers to be used in the system
Kompressor adjustable expansion / compression system
Contour Mode fattens bass output at low to moderate listening levels
Attack Mode enhances the sharp, quick attack in bass and midbass
Redline Mode controls dynamic peaks for a more even output
Digital high- and low-pass crossovers
10Hz – 60Hz variable high-pass frequency adjustable in 1Hz steps
30Hz – 200Hz variable low-pass frequency adjustable in 1Hz steps
6 – 24dB / octave variable high-pass crossover slope
6 – 48dB / octave variable low-pass crossover slope
Digital KickEQ fully parametric equalizer
20Hz – 200Hz variable frequency adjustable in 1Hz steps
0.5 – 10 variable bandwidth (Q) in 0.5 increments
Boost or cut 0 – 18dB in 1dB steps
Selectable phase
UltraMatch gain control circuit
5-stage input circuit for optimal level matching and the best signal-to-noise (S/N) ratio
1, 2, 4, 8, or 16-volt input range selection
12dB adjustment in 0.5dB steps for each input range
Memory presets
4 presets for installers or tweak-a-holics
Each preset is pre-loaded with common settings for easy setup
Customize each preset for quick access
Sick Bay diagnostics
Real-time amplifier diagnostics and troubleshooting
Keeps a running history of past trouble faults
Check current voltage and temperatures
Recall minimum and maximum voltages
Recall minimum and maximum temperatures
ISIS Vacuum Fluorescent Display.
1250 watts rms into 1ohm
Selectable phase
Memory presets
