Kicker sx1200.1 Question Help Please!
DeViOuSoNe
What's a Subwoofer?
Ok well I have a ED 19ov.2 18. I have it in a 3.7 at 32 HZ box after displacement
Just get the sx1200 Mono, and hooked it up at 1 ohm, and I am not as happy as I would of thought, The sub still acts like it needs more power. Birth sheet reads 1283 Or somewhere around there..It gets LOUD and sounds good, But just not as loud I was expecting....
Does anyone know what the power is rated at volt wise? I mean 1200 at 13 volts or so on..I mean they say safely to only give the sub 700ish But up to 1300 If you know what you are doing...There is no distortion or clipping of anykind...The sub is facing up with port firing sidways towards passenger side...Also anyone dealt with these amps before?
They are all digital and a pain in the *** to set Gains and crossover's
anyone with help please let me know...Basically just want to know if I add a second batt would it get louder? Because right now I have The flipout, 2 Headrest Tv's and a 4th tv, plus the kicer Sx and 4 channel amp all running off of the battery
I have JL 4 gauge wire. Should I upgrade that, also?
It is in a 2005 caddy CTS and I have arm rest open...Also has a 20 inch whole from stock sub in rear deck...
I have installed everything myself, and is installed correct...
maybe the sub's just dont get loud? My 15 inch cvr's were wayyy louder sealed off of 800 watts, Just dont get it
DeViOuSoNe
What's a Subwoofer?
DeViOuSoNe
MD
DBfan187
