kicker subs? need suggestions.
bsean63
Undead Revolution
ok i currently have an alpine amp thats rated at 1000 rms at 2 ohms...(mono amp)...... and need subs. which one should i go with?
KICKER 06CVX154 (CVX15")
Features:
Peak Power Handling: 2000W
RMS Power Handling: 1000W
Nominal Impedance: Dual 2 Ohm
Resonance Frequency: 21.5Hz
Qts: 0.304
Vas: 7.3cu.ft. (207.7 L)
Outer Frame Diameter: 15 7/16" (39.2cm)
Hole Cut-Out Diameter: 13 7/8" (35.2cm)
Mounting Depth: 8 1/4" (20.9cm)
08S15L72 Solo-Baric L7 Series 15"
Sensitivity: 88.5 dB
RMS Power Range : 50-1000 Watts
Peak Power Handling: 2000 Watts
Low Frequency response: 18 Hz
High Frequency Response: 100 Hz
Diameter: 15 Inch
or two of these
15" Comp VR sub
1,000 watts max output
500 watts RMS rated
15" high powered competition VR series subwoofer
Mounting Depth: 7-15/16"
Sensitivity: 89.1 dB
Frequency Response: 25-500 Hz
Impedance: 2 ohms Dual Voice Coil
Sealed Box Volume 1.8 - 5.2 cubic feet
Ported Box Volume 3 - 5 cubic feet
Injection Molded Cone with low distortion output
Stamped Steel Basket
Stitched Surrounds
Dual 2 ohm Voice Coils
Vented Pole
Cutout Diameter 13-7/8"
two comp VR 15" is gonna pound bro look at the cone area increase over a single 12"
and you got enough to run them both. Do you have the room to do 2 15" ?
If you have teh room and want to bump do the compVR 2 15" is gonna move a lot of air.
otherwise the CVR is gonna get loud on 1k and sound good doing it.
two comp VR 15" is gonna pound bro look at the cone area increase over a single 12"and you got enough to run them both. Do you have the room to do 2 15" ?
so how would they both sound???? i want good sq but also spl..
bsean63
Undead Revolution
bsean63
ohio
bsean63
