Kicker ss tweeter only works when volume is way up.
Switch your RCAs right to left at the amp. If the tweeter going out switches sides, its not the tweeter/crossover but the amp or head unit.
Switch the xovers from the left speaker to the right speaker and right to left. I would suspect after you do this and double check your connections, you will probably got your answer.
If that doesn't work, seems like a loose connection somewhere else.
Juan
nwo504
nwo504
New Orleans
OldOneEye
