Kicker S12L7 Ported Box.. please?
dirtypwntang
anybody have good specs for a 12" kicker solobaric L7 ported box? i am a n00b to car audio, so please be gentle =]. anybody around so.cal who's willing to help me build one? will pay money or buy much food.. maybe give an old amp i have lying around? think it might be worth a little cash.. blah.. want a new box.. sealed just won't cut it
DIMITRIOS...if you signed up just to post that...why bother? What amp do ya got? J/w... I probably won't be building //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
- pe@ce
well the kicker site says up to 3.25cubic feet... i want around 3.0cubic feet... i listen to just about anything.. but the only time i ever even turn on my subs are when i listen to hip-hop or trance..
the amp is a Hifonics Brutus BX1000D... website says 500W, manual says 700W @ 2ohms... i'd like to believe it's the latter =]
the subsonic filter ranges from 15-35Hz
no, i will not be using this for competition purposes
i'd like to give a good 50/50 between sq and spl... a friend of mine said that better sq would also get the sub lower? it's not as low as i'd like right now, so maybe slight bias towards sq..
the sub is the dual4ohm wired in parallel to get me to a 2ohm load. it wants 750 RMS
wow i edited this post like 5 times
well yes if u put a divider in there to make 2 different boxes. if the 2 subs are going to be in the same chamber then NO.
hey but thanks for using the search button first. we need more people to use that.
u'd have to take ur own dimensions. i doubt it will fit because it'd be 9 cubic feet. what would like outta ur system? sq? spl? sql? what percentage do you want sq/spl?
442
932
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
dirtypwntang
dirtypwntang
pwntangville
ssj2xxgotenxx
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
