kicker question well .............
yes.
you would need an amp and something called a LOC (Lineoutput converter) The LOC will connect to your rear speaker wires and then on the other side it will have to RCA ends that will connect to your amp.
done and done //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
kicker question well really all brands of subs question
can i still power one 15 l7 without a aftermarket H/U?
So long as the amp you are using has high-level (speaker wire) inputs or you incorporate a line-out converter into your setup...
It's about getting signal into the amp you're driving your Solobaric with....not where that signal is coming from //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
say i play my music with that tape that you put in with the wire on the end that you connect to a c.d player.
is that setup possible to play with a l7 15''?
my amp is a pg xenon 1200.1 (SOMETHING LIKE THAT)//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
yes but it will be attenuated a bit (just like cd's are attenuated when switched from radio).
no reason why a tape adapter wouldn't play thru the L7 either. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
sounds like i would make a real cd player my next priority if i were you
in fact, i'd probably make it my 1st over a sub
but yes it will work
you just wont be able to hear any musak above your bass.....
why would i recomend a real cd player first?
well, i guess that was assuming that you were the least bit concerned with sound quality
but since you're considering adding a 1000w subwoofer system to your factory radio, i guess i should be less concerned
go ahead, it'll sound great
what happened to the deck in your sig?
bcleachd
Banned
bcleachd
columbus ohio
bcleachd
