You are scaring me. That's what I have and thought I had 600W going to my single 12 SE.
Maybe you and I both can read this and see if we figured it out right. If not I need another **** amp //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
Details
The KX600.1 Class D amplifier generates 600 watts RMS of power at 2 ohms, drawing less current and producing less heat than traditional amp designs. The built-in variable low-pass crossover (50-250 Hz, 12 dB per octave), KickBass boost (0-18 dB of boost at 40 Hz), and defeatable subsonic filter shape the character of your bass to fit your sub, its enclosure, and the acoustics of your vehicle. The remote gain controller lets you set the amp's KickBass from the dash, so you can make instant low-frequency adjustments to fit the type of music you're playing. The Amp-Strapping circuit allows you to tie together two KX Series amps to power one sub. A removable metal shroud hides all wiring connections for neat installation (it can be left off to save space). Features: 300 Watts RMS x 1 @ 4 Ohms 600 Watts RMS x 1 @ 2 Ohms 25 Hz Subsonic Filter Efficient Class D Amp Design 0-18 dB Kickbass Bass Boost @ 40 Hz Dash-Mountable Remote Bass Level Control Speaker And Preamp Level Inputs Preamp Outputs MOSFET Power Supply Frequency Response: 20-200 Hz 4-Way Protection Circuits Requires 4-Gauge Power And Ground Dimensions (W x H x D): 16-1/16" x 2-9/16" x 10-5/16" (Including Removable Shroud
