Kicker kx gray or zx big 2 or 4 channel
But I bet it cost a pretty penney
I could probably get more local for it than online ...But Id sell it for $200 plus shipping if you want a price figure ...Its a very nice amp...I hadnt really thought about it in a while till you mentioned one...If my sub was the right VC ...I think Id hook it up in my Camaro ...and run it a while for old times sake ...
510
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
d77543020
d77543020
stockton ca
Daniel1500
Brendon Jenness
    May 8, 2024
    May 8, 2024
