Sold Kicker KX 650.4 refurb amp, 160$ shipped
Lurius
I replaced this amp with an Eclipse simply because this monster is BIG, and I only was using 2 of its 4 channels(no more rear speakers). It is in perfect operating order, but was scraped up in one area by a bolt on my folding back seat. Plenty of pics below, birthsheet, endcaps and phone cord(used with bass knob, not included, installer stole it) included and it will be packed within the original box from kicker refurb.
The amplifier manual can be found online here(PDF file): http://www.kicker.com/06/tech-support/manuals/manuals/04KX%20350-650-850_4%20Amplifiers.pdf
From Sound Domain:
KICKER amplifiers have always ruled the winner's circle at car audio competitions because they combine remarkably advanced design features with the highest-grade electronic components and manufacturing tolerances for the ultimate combination of sound quality and brute power. The new KX series stereo amplifiers feature outrageous removable amp shrouds that scream “power.” Beneath the exciting exterior lies fan-cooled internals that have been designed from the ground up to deliver tight, clean power. An unregulated Class A/B power supply allows the amplifier to really pour on the power in 2-ohm operation. All this power is at your command with continuously variable crossovers, high- and low-level inputs, and variable bass boost. Fast-acting protection circuitry guards against short-circuits, over-voltage, overheating, or wiring mishaps. Gold-plated RCA input connectors insure maximum conductivity and resistance to corrosion. High 22kOhm input impedance lets you link multiple amplifiers in a single signal chain without having to use signal-robbing splitters. Custom-tooled remote and speaker screw terminals are also gold-plated, while oversized power and ground terminals allow positive connection for up to 4 gauge wire. Dialing up just the right amount of bass is at your fingertips with the KickBass variable bass boost. KICKER even ships every amp with its own birth certificate – KICKER's guarantee to you that it meets their high standards for power and performance.
Features:
* Radically Advanced Chassis with Removable Chassis Shroud
* Fan Cooled
* Short Circuit, Over-Voltage, Reverse Polarity, Thermal (SORT) Protection
* MOSFET Power Supply
* KickBass 0-18 dB Variable Bass Boost at 40 Hz
* Included Remote KickBass Control
* 12 dB / Octave High- or Low-Pass Crossover
* Variable Crossover Frequency from 50-200 Hz
* Delayed Turn-Off Logic Circuit
* Soft Start Turn-On Circuit for Reduced Startup Load
* Removable EndKaps Cover All Connections
Multi-Channel Amp Specifications
* Amplifier Type: Multi-Channel
* RMS Power @ 4 Ohms: 120W x 4 @ 14.4V
* THD at 4-Ohm RMS Power:
* Bridged RMS Power @ 4 Ohms: 325W x 2 @ 14.4V
* Speaker Level Inputs: yes
* Preamp Outputs: no
* Built-In Crossovers: HP/LP
* Bass Boost: 0 - 18 dB
* Frequency Response: 20-20,000 Hz
* Signal to Noise Ratio: >95 dB
* Fuse Rating: 2 x 40 amps
///End of sound doman text///
Additional info:
22 1/2" long with endcaps, 17 1/2" without. 2.5" tall, and 10.125" wide
The pics:
4ga power/ground inputs
Its missing one of these black plastic clips, if I cant find it you might have to use a washer, or use washers all aroudn might look better. Pics:
The damage:
It also has one small blemish on the opposite side of the scratch/gouge, not too noticible really, visable in a few pics, look above.
I only have one feedback listed below, but look up in the feedback section and you can see ive posted feedback for various other members. I just dident list them simple because they left me no feedback in return, if that makes sense to yall lol. Ebay feedback is like 60-70ish, can be seen on ebay @ LuriusVulpius as the account name.
Im asking 160$ shipped for this to any 48 states(sorry Alaska and Hawaii), pretty firm on the price.
-Lurius
PS: I found the broken tab. Its still usable for appearance I guess, and should hold the amp on fine.
Lurius
Lurius
Arlington, Texas
Lurius
