Hi, i recently just installed a set of kicker components in my dodge dakota, my problem is that only the passenger side works but the tweeters do not. Ok first off i have a premier deh-p860mp pioneer cd player, my amp is a mtx 564. first off yes everything is brand new! right out of the box, and im pretty sure i have hooked everything up right, this is not new to me but it is the first time i have tried to hook up component speakers. Ok i first turned my headunit on with the amp on the high pass filter and i heard a slight pop on my passenger side speakers. then i turned up the gains a bit and started hearing the music from the mid's. and still this is only on the passenger side. so then i decided that maybe the amp has something wrong so i disconnected each speaker output and changed them to the opposite side to see if the driver side would work on the passengers side place on the amp and yet this made no prevail. I got a closer look at one of the crossovers and i see that it makes a weird static sound i'm wondering if this is normal or if my crossovers are blown. I had 12 gauge stinger audio wire running into the crossovers with the standard 18 gauge wire that kicker gives you to the speakers and tweeters. so im not sure what i did wrong, i'm 99.9 percent positive that all the wires are hooked up right.
