SOLD kicker ks6.2 componen/coax set 6.5"
psychoacoustics
hammer and the evil one
3,468
Buffalo NY
1. Product: kicker k6.5" component set
2. Specs:
* 1" Titanium Dome Tweeter
* 6-1/2" Polygraphite Woofer with Titanium-Deposit Coating
* Treated Foam Surround
* 2-way 4,500 Hz Crossover Network (12 dB/octave high- and low-pass)
* Frequency Response 35-21,000 Hz
* RMS Power Handling: 6-75 watts
* Peak Power Handling 150 watts
* Sensitivity: 88 dB
* Top-mount Depth 1-15/16"
3. Description/Condition:
used as a comp set but can be converted to coax
comes with all 3 tweeter mounting options xovers box grills (never used the grills they were in a door)
wires on tweeters are cut short but works 100%
4. Price: : 100 shipped
they were 250 new
hey, do you have the crossovers? I dont need the speakers but I need a pair of good kicker crossovers that start at say 2.8k and go up to 12000k. You have anything like thatlaying around?
908
psychoacoustics
psychoacoustics
Buffalo NY
psychoacoustics
