Kicker DX350 350W Class D Mono Amplifier
  • 2
chaz7979
boston
Here comes another newbie question. Can I run two 4ohm woofers in parallel to this amp? (Kicker DX350 350W Class D Mono Amplifier ) It says it puts out 350 2ohm bridged. Also does anyone have anything bad to say about this amp?
I don't think it actually says "bridged," because its already a mono amp. But to answer your question, yes, running those subs in parallel would give you the 350w they were talking about.
I had a Kicker amp and it cut off on me all the time. That's my only experience with Kicker amps. It sure did make my subs sound good though. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
786
chaz7979
chaz7979
boston
wesleysh
    May 31, 2024
    May 24, 2024
