Kicker CVX vs L7
csnut18
Hey everyone, I am looking to get either a kicker vs10L7 or a vcvx10. The vs contains a 10" L7 while the cvx has a 10" cvx sub. Both are rated to handle 600 watts rms. I would be powering either one with a polk momo c500.1 providing 550 watts at 2 ohms(that is what it said on the birthsheet) which I already have running my current sub setup. I was wondering what the is soundwise between the cvx and the L7. Thank you so much in advance.
dont know from personal experience but i have heard both are really closei've heard that the cvx has a little better sq as it is a round sub and the L7 is a bit louder hence the square cone
biggest difference is cone area. do a search on that.
area of a circle vs area of a square. motor should be the same tho from what i've read.
BTW: are you going to port it?
if not go CVX, if port, either way is fine.
I am getting one of the prefab kicker factory enclsures that come loaded with the sub straight from kicker. It comes ported. The cvx is cheaper so I thought their must be a reason.
How will a kicker l7 compare to a polk audio sr124? I have that in my car now but I am giving it to my brother. I had it in a box wich was 1.21 cu ft which is a bit bigger than what they called for.
probably not compareable at all.. polk sub FTL:crap:
That polk is a very high end sub. Its expensive. Are you sure the kicker is so much better? I hope you are right that the kicker is better.
I have a polk momo c500.1 in my car now. What sub would you recommend? By the way, I have an 06 acura rsx type s.
That amp is putting out 550 watts at two ohms. That is what it said on the birthsheet. My rsx is small and a hatch so less power is needed. Even if you recommend a expensive sub, if it is sold on ebay, I am sure i can get a good deal. What do you recommend over the l7?
csnut18
csnut18
NYC
csnut18
