Kicker Comp help
  • 1
Gage6822
I just got finished installing 2 Kicker Comps in my car and trned everything on. My Right side sub hit great but my left side wouldn't hit at all then like a second later it started smoking (I ran as fast as i could to turn of my HU. I checked all the wiring all of it was correct. This same exact thing happened to my old subs also. Is it my amp or the connections in my box? And does smoke automatically mean my sub is shot cause i just bought these?
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
482
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
973
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
Gage6822
Gage6822
Gallatin, TN
Gage6822
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
