ok i'm cleanin house and in a bad way, i really need the money and have decided that this poop needs to go, im done with competition untill i can afford to build something right and not nickel and dime myself to death.
1 set memphis multisync components 6.5 inch when i got them they had massive audio tweets because the memphis one blew so i ordered so replacements from memphis and well i blew em, the massive audio tweets sound better anyways you just cant put them on the cone of the woofer.. oh and i also had to get replacement crossovers (dont ask ), so those are new.. $80
3 selenium extreme 15's dual 2 low play time probably under 4 minutes.. i have more but not sure i wanna get rid of them all. these have not been in my truck and were not blown up.$120 each or $300 takes these 3
1 ma audio hk3000d needs 3 mosfets replaced otherwise in great shape (sorry alan hall i never got back to you about this things have been crazy) mean amp ran @ .25 on 12volts and didnt even get warm the amp is rated under 300 @ 4 ohm amp is not modded for 16volt but i have the diagram for the mod i can send. ummm make me an offer
1 orion cobalt cs100.2 ran my front stage till i blew the tweets then i put it back in the box and used headunit power still have the box and manual
$40
Features
Variable high pass crossover 30Hz-1kHz
Variable low pass crossover 30Hz to 2.5kHz
XBC12 Bass Boost
8 gauge power/ground
16 gauge speaker
High efficiency heatsink
PWM power supply
100% QC Tested
2 Ch x 50 Watts @ 4 Ohms
2 Ch x 100 Watts @ 2 Ohms
1 Ch x 200 Watts @ 4 Ohms
Signal Processing: continuously variable high pass (50Hz-1kHz) or low pass 30Hz-250Hz
Fuse Size: (1)20 AMP ATC
Dimensions: 5.7" x 10.1" x 2"
1 kenwood kdc-x789 missing the trim ring and the battery cover for the remote 3-5 volt outputs and an aux input g analyzer screensavers all that happy horse poop $175
1 kicker l7 12 dual 4 older one works $75
1 american bass (old) vfl 15 i dailyed 2 of these in my ranger with 2 cx1500d's on them for a long time this one snaped a tinsle lead and was reconed with atomic apx soft parts would make a great daily sub that can hold a good amount of power 10 minutes of play time to make sure it stayed together after recone and it did great on music $120
and last but not least
1988 chevy s10 extended cab, 2.8 v6 5 speed 4x4odometer shows 293,xxx miles just put a newer motor with under 120,xxx miles in it this summer the ***** and transfer case have been rebuilt at some point in time before i owned it good clutch new throwout bearing it's flat black body is a little rough newer alternator, new shocks new master cylender new passenger front caliper and brake hose and new brakes all the way around. needs a headliner some carpet and the front bumper is bent. has solid back window windshield is solid bucket seats lap belt seatbelts and no interior in the extended cab except for the trim above the windowline, brandnew fullsize spare tire truck didnt come with a/c needs the timing set it runs fine just idles high starts every day , i dailydrive it at least 5 days a week. it's not a show truck but i only want $750 for it it's a good spl truck or winter beater, the plastic delta tool box goes with it i dont want it
pics should be up from my crappy camera phone sometime later this morning when it's light out.. i take paypal(+3%) cash and postal money orders all items are + shipping
$40
Features
XBC12 Bass Boost
16 gauge speaker
PWM power supply
100% QC Tested
