Kicker 17 15'' or ?
For SPl they are pretty loud for less money there is not much that can hang.
18" Fi Q. will get loud on 1k.
You owuld be better off with a 4.5 cubes and 1 15" L7 un less you have plenty of space in your car, a single 18" might be a good compromise.
^ wow i surprised it wasnt said earlier. 1000watts is not enough power for 2L7 15s period.
you need atleast 1500 to get the potential out of those subs
2 ported 15s will take up alot of room 9ish cubes.....unless you have an suv then you probably wont have enough room. I say 1 ported off of 1Kw will do you better
Make sure you get the 08 model L7s. Heard they're suppose to be way better. Read the link: http://www.sonicelectronix.com/item_11344_Kicker+Solo-Baric+L7+Series+08S15L72.html
Get the L7s at onlinecarstereo.com They are most likely going to be the cheapest and offer a one year warranty.
That amp wont be enough to power those subs. What kind of vehicle are these going in? If its a car just put 1 15 L7 and that Alpine 1000.1 amp. That will be good and plenty loud. You might as well get a 12 inch kicker solo X. Because the price difference isn't much
http://www.onlinecarstereo.com/CarAudio/ShoppingCart.aspx
I have a tahoe so two subs will fit.
so one l7 will be louder than 2 l7 with the same amp in a ported box?
yes one will be louder than 2 with that amp. if you have good money and all.. i would say get a 3000 watt amp, the 2 08 L7s, and some good electrical stuff to be all set. with that 1K amp, i would only run one 15. i will vouch that the 08 L7 is better than the previous models too. i love mine!
I have a tahoe so two subs will fit.so one l7 will be louder than 2 l7 with the same amp in a ported box?
Yea but the only reason why is cuz that amp wont push 2 kicker L7s. Because the amp only handles 1000 watts rms and one 15 L7 can push 1000 watt rms. So if you put 2 L7s on that amp they will only get 500 watts rms to each sub. And they should have 1000 watts rms each. hope that makes since.
yes i am going with one 15'' . but im wasting about $300 just on the box. i believe the box makes a huge difference
youngcoke
Banned
youngcoke
chicago
Famous_78
