Kicker 12" L5 hatchback enclosure
Beautiful enclosure man! ONe question,how do you keep the excess glue from showing from around the joints? Do you just sand it down?
I don't know how he does it but you can just wipe it off with a wet rag while it's still wet.
I love the mix of paint and carpet you usually do. I've never seen better looking boxes than you build.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
708
THUMPPER
Pound That Sound
THUMPPER
Salmon Arm BC Canada
BobbyDD
    May 20, 2024
    May 20, 2024
