SOLD Kicker 1/0ga Hyperfelx & Fosgate 2/0ga Super-Flex and Inline Fuse Holders FS
QtrHorse
It's my first day!
1,548
Tx
I have some wire and a couple inline fuse holders for sale.
I have not been on the forums in a very long time but I had perfect feedback before I left.
All the wire is new. I have had this wire for about 2 years and need to get rid of it.
I am only looking for one item in trade. I need a small/ low profile 2 channel or 4 channel good quality amp. It needs to be able to run at 50x2 to 75x2. I am not looking for anything cheap so don't even offer.
I have about 30 sheets of Second Skin Audio Damplifier that I will be listing in the next 3-5 days as well along with about 225ft of 16ga Stinger HPM speaker wire (SWX16PUR2).
225ft of 16ga Stinger HPM twisted speaker wire (SWX16PUR2). This is the speaker wire that has a purple and silver wire inside a clear outer cover.
$15 shipped for 50ft.
I have two new KnuKonceptz 1/0ga inline ANL fuse holders for sale. One has a 300A fuse and the other will have a 250A fuse.
$19 shipped each. If you buy these with any wire purchase, I will include them for $16 each.
Pictures of the wire at the bottom of this thread.
I have the following pcs. of Kicker Hyperflex 1/0ga wire.
If multiple pcs of wire are purchased, the total will be a little less because of combined shipping.
$27 shipped - 9ft4in gray SOLD
$60 shipped - 20ft gray SOLD
$15 shipped - 5ft blue
$46 shipped - 15ft8in blue SOLD
$60 shipped - 20ft blue
The following pcs of wire I will only be selling as a package because it is kind of odd unless I can get takers for all of it. I will also be including 6 2/0ga tinned ring terminals.
It is Fosgate 2/0ga Super-Flex in red only. The two pcs of 13ft2in are taped together with black electrical tape. This wire has 5929 strands.
9'9" with a ring terminal on one end
13ft2in
13ft2in
2ft2in with a ring terminal on one end (this pc was screwed down and then removed with out having power ran through it)
3ft10in with a ring terminal on one end
4ft7in with a ring terminal on one end
$145 shipped SOLD
This last picture is a comparison of the Kicker and Fosgate wire next to each other.
what do you have left in hyperflex?
Vitveet has first choice. I'm getting him some info on other items I have for sale. He may buy it all.
I will let you know if the deal does not go through.
Very true; how often does that happen? If you look at my Paypal feedback, it would have showed that I have had perfect transactions as of the day he paid and after. Oh well, there is always one bad apple and I found mine.
It's fascinating you feel this isn't your fault. I feel the negative feedback is appropriate, 16 days without the item delivered or a tracking number provided. If I sold an item to anyone and did the same I'd expect negative feedback.
And as I said in PM, if it arrives postmarked on November 10th I'll even be kind enough to remove the negative post about you. But I doubt you shipped it on the 10th as you said you would.
See my responses in bold below. I shoud not have added the "but" comments because that makes it sound like I'm not taking responsibility.
It was my fault. I should have at least kept you udated, that is what I would have wanted.
Good lesson yes but unwarranted negative feedback or at least give me a little more time. I don't check the forum very much and I should have, my fault. I did not receive an email from you recently or I would have replied to that.
I did ship your item late, my fault. Maybe just a little more time before filing negative feedback would have been nice. You do have 45 days to file a claim with Paypal.
Yes, I do value my feedback and packing skills very much. It's dumb but it's just something I value. I guess I'm just a little bummed because I did not follow through with my part about shipping it out on time and now I have a hit against my feedback score. The first in about 15 years.
Like I said, good luck with the install and hopefully everything works out well for you.
876
QtrHorse
It's my first day!
QtrHorse
Tx
corcraft
