Kenwood Setup
Forgive me because I am really new to the car audio scene... I just need some advise as to whether or not this setup I saw at BestBuy was good or not.
All help is appreciated, here are the details.
Kenwood - 500W Class D Mono Amplifier with Crossover
Product Height 2-1/2"
Product Width 12-1/2"
Product Weight 6.4 lbs.
Product Depth 11-1/4"
Continuous Watts per Channel (4 Ohms) 300 x 1
Continuous Watts per Channel (2 Ohms) 500 x 1
Max Power Watts per Channel (4 Ohms) 300
Max Power Watts per Channel (2 Ohms) 500
Max Power Watts per Channel (4 Ohms Bridged) 1000
Number of Channels 1
Crossover Yes
1 Ohm Stable Yes
Amplifier Class and Type Class D
Low-Pass Filter Yes
Line-Level Input Yes
Speaker-Level Input Yes
Crossover Frequency Range 40-200Hz
Bass Boost No
Passthrough Yes
Fan Cooled Yes
Kenwood - 12" 4-Ohm Single-Voice-Coil Subwoofer KFC-W3011
Product Height 12-13/16"
Product Width 12-13/16"
Product Weight 15.4 lbs.
Product Depth 7-11/16"
Woofer Size 12"
Woofer Material Polypropylene
Magnet Size 48.2 oz.
Magnet Type Ferrite
Continuous Power Handling 400W
Peak Power Handling 1200W
Impedance 4 ohms
Number of Voice Coils 1
Efficiency 90dB
Surround Material Rubber
Recommended Installation Type Sealed box
And it comes with a box for the 2 12's, Q-Logic - 12" Dual-Chamber Subwoofer Enclosure. All for about 330$.
I mean, I would love to, but I don't really have the time... For now I'd just like to get something installed that would sound really good and wouldn't break my bank you know?
go to circuit city then..
get this sub package
http://www.circuitcity.com/ssm/Kicker-Dual-Subwoofer-Enclosure-Package-05DC122/sem/rpsm/oid/145731/catOid/-13093/rpem/ccd/productDetail.do
now you want that particular one because its wired to 2ohms, you don't want the 4ohm one.
then buy this http://www.circuitcity.com/ccd/productDetail.do?oid=146771&c=1
because its 100 dollars off when you buy a kicker box with that amp.
that 300.1 should run 300 rms @ 2ohms to those subs which are 300 rms. So matches perfect. Total is around 350 and gives you 150 bucks for your install.
Archetype
Archetype
Sacramento, CA
DaveDSMer
