Kenwood Nav in Nissan Altma
Biker
Can someone give me a brief instalation process to remove a stock radio single CD player and Install a Kenwood DNX-9140 Navagation system in at 2008 Altma SE. Is this a cut and hack instalation. Can it be done by a novice? Do the speaker wires land there or come from an Amp somewhere? I know only theres a seperate fuse for an amp but have no idea where the amp is located.
Am just asking about the Dash instalation. I can do the rest fine.
Thanks
Ok Guys thanks, I get it now. The instructions at least will help me get the Radio out and I ordered the Dash Kit today. Hopefully there will be some additional instructions with the Dash Kit but I think ill be ok now.
Thanks Biker
take out the heat/ac vents above the stock cd player and there is a small plate below the heating/ac controls. there are 2 phillips screws behind both spots then the stock head unit should pop right out. you will need to take the metal brackets off of the stock unit and mount them to the sides of the nav unit. I just put an AVIC-Z2 in my 09 altima and can help you more if you need.
These instructions above are to mount some bracket to my car that I dont need Please help. Thanks Biker
it's just to show you how to get the radio out. everything else should be pretty self explanatory.
Biker
Biker
Tracy, CA
x1le
