Djltoronto
I have 2 of these economy 10" subs, and one of them makes a distinct "sound" when being played near it's limits.
The 2 subs are in dedicated sealed chambers, 0.78 cu.ft each, running parallel of a mono amplifier, and when near it's mechanical limit, very clearly, one of them makes a difficult to describe sound, almost sounds like an amplifier clipping or like a mild bottoming out of the VC against the magnet - but that's not the case.
I pulled the sub out of the box and noticed that the spider is essentially defective and has a "soft spot" near the VC.. (if a picture is worth a 1000 words, hopefully this video will explain what I am trying to describe).
As I press on the cone lightly with gradually increasing force, there is a point where the suspension just falls a few MM's (as the spider essentially folds - see vid). I am virtually positive this is causing the abnormal sound when played at high levels.
Is this fixable? or simply not worth it cause it's a cheapy sub?
Click for video: See second Roll/fold on spider from the voice coil.
Dragon Spider DesignKenwood's Dragon spider design helps improve the speaker's mechanical stability, for better power handling with less wear and tear. LOL yeah right!
