Kenwood KDC - x996 issues....
rebelliondog206
I am experiencing difficulties with a new x996.....
I just hooked it up today (correctly, I believe) and I seem to not be getting signal out for the front otuputs. I can barely hear music through the front speakers.....when the sub outs are hooked up, they seem to play fine.
Here is the set up......X996 out to two amps, one Alpine for the subs (seems to work fine)....front outputs to a Polk MOMO 300.2 (was just working with the other head unit). I am not getting a full signal out to the 2 channel, I do not think. Volume at max on the head unit and gain set up to 75% is barely audible Through the front speakers now....was fine before this new head unit.
I have checked and rechecked my wiring and it looks good (same as when it was working with the last head unit).
Is there anything that Kenwoods are known for that would cause this? Has anyone else received a defective unit when purchasing new?
I hope I explained myself clearly enough for everyone to understand and help if possible.....
assuming the RCA's aren't bad, the HU may have an issue. did you connect to front or rear preouts? where is fader set?
usually when music is "barely audible at max volume" there isn't any output from the connected RCA's and what you hear is bleed-through from other channels - or crossovers are cancelling each other.
what if you connect the sub preouts to the 300.2 inputs (and defeat any crossover). verify the 300.2 crossover is HPF and not LPF by accident.
is there a LPF activated on the HU outputs you are using? i would defeat (flatten) any crossovers.
Yep......found the problem after a good night's sleep.
You were right on the mark about bleedthrough.
Rookie mistake......looking at all the wiring must have had me confused. I simply had the the ends of my signal cables marked wrong and therefore was plugging / swapping them wrong.
Kenwood KDC - x996 first impression: This thing kicks a**. Adjustments for everything imaginable and sounds considerably better than the budget unit I replaced. Little glare on the face as is in just about all the reviews. I'll see how it goes.
Thanks for the reply.
rebelliondog206
rebelliondog206
Texas
ewadz3006
