Kenwood KAC-650 5 ch.
NJAV1
I give her pleasure....
I got this Kenwood a few years ago...the thing is I can't find this friggin' thing anywhere on the net...I tried the Kenwood site, searches and googles and nothing comes back on this thing. Was I the only person in the world to get this amp?..//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
I want to confirm Rms x 4....on this thing before I commit to the comps....
Dave
//content.invisioncic.com/y282845/emoticons/wave.gif.002382ce7d7c19757ab945cc69819de1.gif Welcome to the forum, Dave.
Are you searching for the model KAC-650 exactly? If so that could be a part of your problem....the proper model number is KAC-X650.
****!!!..Thanks Prowler..your right all my searches were for KAC-650's....let me see if I can find the specs on this thing....
Thanks for the welcome dude...
Here's the specs I found..it helps when you use the right search criteria...LOL
60 watts RMS x 4 + 200W x 1 at 4 ohms
80 watts RMS x 4 + 300W x 1 at 2 ohms
160 watts RMS x 2 bridged + 200W x 1 at 4 ohms
3-, 4-, or 5-channel output
Tri-way capable (Tri-Way Crossover required)
Bass Management System
infrasonic filter (15 Hz, 24 dB/octave)
12 dB bass boost variable from 40-100 Hz (expandable to 6/12/18 dB when connected to a Kenwood Excelon receiver equipped with BMS controls)
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
cooling fan
speaker short, low battery, thermal overload, and DC protection
variable color indicator
gold-plated terminals
detachable terminal covers
50-200 Hz crossovers: high-pass on front and rear channels (12 dB/octave), low-pass on rear and sub channels (24 dB/octave)
NJAV1
NJAV1
Middlesex County, NJ
NJAV1
