Sold Kenwood DDX-8017 and addons
I understand. I guess my point is that this is the last of the 5v double-dins with the 24-bit DACs. for a SQ guy who wants nav/double-din, this is the unit to have.
Again, I'm open to negotiation on my prices //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
For that year?
For that year?
Are they back to having 24-bit DACs and 5V preouts? After I got this the next year or so didn't have any double-dins with 24bit/5V.
the 25th ae did, but it was a single-din and the controls-on-bottom series of double-dins were 2V / 1-bit.
I haven't kept up with audio in the past year so if they do again, I am incorrect.
once again, my prices are flexible.
from what I remember, yes.
It has a highly customizable crossover and equalizer. might check crutchfield to make sure.
i just had someone in another thread tell me the only active solution for a double din nav unit is to run an alpine w205/505 with h701 //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
if it can indeed go active, i may be able to work out a local pickup.
quote from crutchfields site:
System E's+ Advanced Crossover System: The System E's+ Advanced Crossover system allows you to tailor your system with selectable crossover points for all channels. For the center, front, and rear channels, there is a high-pass filter with independently selectable crossover points of 30Hz, 40Hz, 50Hz, 60Hz, 70Hz, 80Hz, 90Hz, 100Hz, 120Hz, 150Hz, 180Hz, 220Hz, 250Hz or Thru (no filter). You can independently set the level for the front left, front right, center, rear left, and rear right speakers between -10dB and +10dB. The non-fading preamp output, for use with subwoofer amplifiers, has a low-pass filter with a selectable cutoff frequency of 30Hz, 40Hz, 50Hz, 60Hz, 70Hz, 80Hz, 90Hz, 100Hz, 120Hz, 150Hz, 180Hz, 220Hz, 250Hz or Thru (no filter). You can also set the phase of the subwoofer output to normal or reverse, the slope at 12dB/oct., 18dB/oct., or 24dB/oct., and adjust the level of the output from -50 to +10 in 1dB steps.
looks like it can run high-pass for mids/highs, not low-pass...if I'm reading that correctly.
Ya mine has 5v with the 24-bit also the dnx-8120 and the 09 models do. Just trying to help you get the info correct sorry to bother you again and gl with sale.
Cool, I just remember being very happy with mine because it was "the last of it's kind" according to our local shops. Apparently they didn't sell well and Kenwood was going to drop it (and IIRC, did for atleast a year).
anyway, thanks for bringing that to my attention...makes me excited to think about getting another one down the road. //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
camflan
camflan
Lawrence, KS
kenbei
