Keeping up with the bass
ascitiesburn69
Ok I am getting either 2 12" DC level 3s or 2 12" AQ sdc2.5s either of them off 1400-1600wrms. As of now I have a pair of PG rsd65cs components in the front and some cheap pioneer coaxs in the back which are usually turned off. I have a cadence txa3000 for the pg rsds so about 150wrms to each side unless the cadence is underrated not exactly sure. Would it better louder/better to get an additional set of PG rsd65cs for the back and run it off the same amp so around 75watts to each set. Or Get a good, efficient set of coaxials(oxymoron I know...) for the back and run them off the head unit. Or get a different, more efficient set of components for the front and ditch the rears or put the pg rsds in the back.
Thanks
are you trying for SQL?
what is your budget?
If i where you i would ditch to rear speakers, & look into better sounding comp set,ID,Hertz,Zapco,Morel,Rainbowetc....
are your doors deaden??
placement & aiming will help also.
Basically I am looking to get the speakers as loud as possible without sounding like a deaf person screaming into the telephone.....in other words basically just to get louder than i have but sound as good or better.
ascitiesburn69
ascitiesburn69
New Orleans, LA
ascitiesburn69
