Kac9405 amp with 6 Speaker?
zemaq
Hi guys, Ive got a question which i have googled it for hours but couldnt find the right answer..
I have got Kenwood Kac9405 4 ch amp. Maximum Power Output
• 720W
Rated Power Output (14.4V )
• 60Wx4 (14.4V / 4Ohm)
• 90Wx4 (14.4V / 2Ohm)
• 180Wx2 (14.4V / Bridged)
General Features
• 2ohms Load Capability
• Speaker Level Input
• Signal Sensing Turn-On
• Cooling Fan
• Aluminum Die Cast Heat Sink
• Power MOS-FET Switching Power Supply
• Triangle Indicator & Blue Illumination
• Built-in Variable Low-pass Filter 50-200Hz (-12dB/oct)
• Built-in Variable High-pass Filter 50-200Hz (-12dB/oct)
• Bass Boost f=40Hz Gain 0 - 18dB (only Bch)
• Size: W 280.0mm x H 59.0mm x D 238.0mm
2 of Pioneer Ts-a6963e
Woofer Cone Material: Carbon Graphite IMPP Interlaced Aramid/Basalt Fiber Cone
Magnet: 320g(11oz)
Mid-Range: 57mm 2-1/4'Dia. Paper Cone
Tweeter: 11mm 3/8'Dia. PET Film Dome
Basket Design: Shallow Mount
Speaker Grille: Included
Watts MAX. Music Power: 300 Watts
Watts Nominal Power Handling: 40 Watts
Frequency Response: 31Hz~37kHz
Sensitivity: (1W/1m)91dB
Ohm Rating: 4 ohm
Mounting Depth: 2-7/8' (72mm)
Cut-out Dimensions:6' x 8-5/8' (151mm x 220mm)
2 of Pioneer Tsa1674s
Maximum input power 300 W
Nominal input power 35 W
Impedance 4Ω
Frequency response 37 – 30,000 Hz
Sensitivity (1W/1m) 90 dB
Woofer material Carbon Graphite IMPP Interlaced Aramid Fiber Cone
Tweeter size (mm) 11,0 mm
Midrange size (mm) 42,0 mm
I also got an gdm7500m feeds 308d4sb
I am going to install it to my new car from scratch. But there is factory speaker at back doors and i am planning to buy 2 more 6" speakers. Those might be TS-A1684S or something similar. The question is, if my amp would be capable of running 6 speakers, im planning to parallel connect 4 speakers to the rear output. Wondering is that would be allright or do i need to buy different type of speaker or wiring?
I also need some advise on amp wires for both mono amp and 4ch amp to 6 speaker wire..
thank you for your time in advance..
cheers..
Hakan.
zemaq
zemaq
Sydney
maylar
