JVC or Pioneer DD?
  • 2
ace_800
Ok so I have a Pioneer 3300bt installed right now, 4v 6 channel preouts, doesn't stream music but has BT, no nav adapter. I got a JVC kw-nt3hdt from wone that I was going to install in my wifes Lexus to replace a crappy Kenwood DD. Its 2.5v 5 channel preout, stream and bluetooth with nav.
I've never run JVC, so would I be better off running the JVC for streaming and nav or staying with the pioneer? Nav's a plus but I really wanted streaming, but can deal without if the Pioneer is better overall.
Google do it translate what ever i do
380
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
ace_800
ace_800
Okinawa, Japan
subzero
