JVC KD-SH707 Opinions please
BossManWilds
JVC KD-SH707
  • MP3 Playback with CD-R/RW Compatibility
    Motorized Slide-Out Aluminum Face
    New Titanium-Finish Detachable Faceplate
    Multi-Color LCD Display
    Dimmer Control
    Audible Control Confirmation
    iEQ Intelligent Equalizer
    HS-IIIi Tuner
    VCR / DVD Control
    Direct Track Access
    Advanced Sound Control Memory
    Front Adjustable Line Input
    Pop-Out Rotary Encoder
    4-Volt Line Outputs with Subwoofer Level Control
    Amp Defeat Switch
    1-Bit D/A Converter with 24-Bit Resolution
    Card Type Remote Control
  • Anti Theft: Removable Faceplate
    Preamp Outputs: 3 sets
    Preamp Output Voltage: 2 volts
    CD Changer Controls: Yes
    Remote Control: Yes
    RMS Power: 19W x 4
    Peak Power: 50W x 4
    CD Frequency Response: 5-20,000 Hz
    FM Mono Sensitivity: 11.3 dBf
    CD Signal-to-Noise Ratio: 102 dB
I am looking to replace my old Jvc head unit i bought a while ago and ran accross this one. My old JVC is great and I have had no trouble with it, but i am in the mood to add more power to my system. Could anyone please tell me their opinions on this head unit, or if you have other suggestions, they are welcome
Thanks
BossManWilds
Google do it translate what ever i do
375
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
BossManWilds
BossManWilds
Pennsylvania
ss3079
