Jvc Kd-R600
Tw1st3d13
Is this a good head unit? I bought one and its in the mail on its way!!
It has 30 colors to choose from, I got it because I bought a 3.1 million color interior led kit with 6 15" led tubes!!!
Im new to headunits i have only ever used stock Hu's
specs
# Audio amplifier section
# Power Output: 20 W RMS x 4 Channels at 4 Ohms and less than 1% THD+N
# Signal-to-Noise Ratio: 80 dBA (reference: 1 W into 4 Ohms)
# Load Impedance: 4 Ohms (4 Ohms to 8 Ohms allowance)
# Tone Control Range: Bass: +/-12 dB (60 Hz, 80 Hz, 100 Hz, 200 Hz) Q0.5, Q1.0, Q1.5, Q2.0; Middle: +/-12 dB (500 Hz, 1.0 kHz, 1.5 kHz, 2.5 kHz) Q0.75, Q1.0, Q1.25, Q1.5; Treble: +/-12 dB (10.0 kHz, 12.5 kHz, 15.0 kHz, 17.5) Q=fixed
# Frequency Response: 40 Hz to 20,000 Hz
# Line-Out Level/Impedance: 2.5 V/20 kOhms load (full scale)
# Output Impedance: 1 kOhms
# Subwoofer-Out Level/Impedance: 2.5 V/20 kOhms load (full scale)
# Tuner section
# FM Frequency Range: 87.5 MHz to 107.9 MHz (with channel interval set to 100 kHz or 200 kHz); 87.5 MHz to 108.0 MHz (with channel interval set to 50 kHz)
# AM Frequency Range: 530 kHz to 1 710 kHz (with channel interval set to 10 kHz); 531 kHz to 1 602 kHz (with channel interval set to 9 kHz)
# FM Tuner
# Usable Sensitivity: 9.3 dBf (0.8 uV/75 Ohms)
# 50 dB Quieting Sensitivity: 16.3 dBf (1.8 uV/75 Ohms)
# Alternate Channel Selectivity (400 kHz): 65 dB
# Frequency Response: 40 Hz to 15,000 Hz
# Stereo Separation: 40 dB
# AM Tuner
# Sensitivity/Selectivity: 20 uV/40 dB
# CD player section
# Type: Compact disc player
# Signal Detection System: Non-contact optical pickup (semiconductor laser)
# Number of channels: 2 channels (stereo)
# Frequency Response: 5 Hz to 20,000 Hz
# Dynamic Range: 96 dB
# Signal-to-Noise Ratio: 98 dB
# Wow and Flutter: Less than measurable limit
# MP3 Decoding Format: MPEG1/2 Audio Layer 3
# Max. Bit Rate: 320 kbps
eh JVC is tolerable... a lot of annoying problems and mechanical issues with them in the past. I personally stay away from them due to too many customer complaints when I sell them. You get what you pay for! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So you like it alot? i just bought a car yesterday planning on starting the install SOON!! Im lonley with no boom
Well yeah, 5v rca preouts, oel color screen, active capable, 4 different angles, its a powerhouse. I owned a 580MP, 780MP and a 880PRS, and i like the ease of use from Pioneer, but as far as power and sw go, JVC ftw
The new jvc's are alot better than the old ones. I havent had any problems with the new ones. The KDR 600 is a decent deck for the money.Its mostly flashy.The color options are cool and it works well. The only thing with the JVC's are they are complicated. it takes i little while to get used too. But for the price and features, I like them
i like it nice and simple besides its my first head unit besides the gay sony dull green shit for 40$ lmao i could upgrade but not likely in the near future
yeah its pretty sexy I didn't even set it up that was without the settings messed with people say its complicated but I memorized everything I need to know after an hour or so I'm really happy with it and would recommend it to anyone on a budget
Tw1st3d13
Tw1st3d13
Kansas City
Tw1st3d13
