toaster
Installer, since 1984
All,
As stated, I would like to clarify what is causing most of these issues with bad smelling woofers in ported enclosures. Again, this is only for ported enclosures. Sealed enclosures will not experience this issue. Most of the newer digital music these days has notes that go all the way down to 20-25 cycles. Most ported enclosure applications call for tuning anywhere from 32 cycles all the way up to 50 cycles. What you need to remember is that, with any ported enclosure, your woofer has virtually NO power handling at frequencies lower than your box is tuned to. The reason for this is the mechanical damping of the enclosure itself. When you put your woofer into a box tuned to a certain frequency, you are tuning the entire woofer system, which includes the woofers and enclosure, and the environment immediately surrounding the system, to a certain resonant frequency. When you play a song or tone that goes below whatever your woofer setup is tuned to, it cannot control the woofer motor's movement, and the entire system becomes unstable. At that point, there are only two things preventing the woofer to destroy itself:
1. The electrical damping factor of the amplifier circuit. Don't count on this to be of much help, especially with today's "d-class" amplifiers.
2. Time. This is the biggest factor. Anything more than a few seconds with a woofer running at near excursion capabilities will destroy your speaker.
Here is a test to visually see exactly what I am writing about:
Go out to your car, and queue up a test tone cd at VERY LOW VOLUME. Turn to the track on the cd with a test tone at or around 20-25 cycles, and watch your woofers. See how much further in and out they travel? That is because the entire system is unstable.
PREVENTION: If your amplifier has a subsonic filter, adjust it a few cycles under whatever your woofer enclosure is tuned to. This will prevent damaging information from ever reaching your woofer system. If you do not have a subsonic filter and you run a ported enclosure, you really need to buy one. If you do not, then you must be very careful with test tone and "bass" cds.
I hope this cleared up some of the confusion I am seeing with regards to this issue. I keep seeing threads with everyone saying that amp clipping is the cause of bad smelling woofers, but most of the time this is not the case. The distortion and clipping issue has probably been beaten to death on this board, but I will comment on it if everyone would like to hear more.
