Jolly rancher sized volt meter, where can i find it?
JoshC
The Taco MASTA
I remember someone posting a link to some really small LCD volt meters. Pics there posted of it beside a jolly rancher and they were like the same size. Ive tryed searching but couldnt find it again, anyone remember or know where i can get one that small? Ebay had like 3x1.5s at smallest i found
On a side note, should i connect its power threw the remote wire to my HU or where would be most effective? I dont mind running a wire to the distro block if I need too.
Is this what you're looking for? :p
0.36inch Digital Panel Voltmeter 0-100V Blue LED Voltmeter - Free Shipping
Here's the pic to prove it!
YES! and WINNNN!!!! Thank you sir, now what area should i connect its power wire to?????
the best thing to do is connect it to the amps power and ground
if it has its own accessory wire attach the remote to it and the pos and neg at the amp terminals.
honestly attaching it to the remote will prolly work plenty fine but it wont be as accurate due to the radio's built in capacitors
on this meter the black is grounded, red is attached to an accessory wire or remote and the green goes to the amp +
Ok, and im guessing i should attach it to my sub amp since its pushing alot more amps right?
depending on how far your distro block is from the sub amp i might would ust attach it there.
if you have more than 2 ft in between your bass amp and the distro attach it to the amp
if you have a batt in the back attach it to the amp
Distro block is about a foot or so from each amp, single cab truck lol
JoshC
The Taco MASTA
JoshC
Houston, tx
Bettr n' Revrse
