jl OR alphasonik
mustangmoe
whats up i want to pick from these two speakers and i will like some suggestions
im looking for the most power i see the mayhem has 2200rms but is jls 1000rms just as good ?
PSW912 this is a 12 in sub
12” ALPHA MAYHEM 900 SERIES SUBWOOFER
Cast Aluminum Machine Cut “Alpha” Basket
Motor Assembly Heat Sink
Ultra Light 2-Layer Carbon Fiber, Kevlar® Cone
with Aluminum Dust Cap
New TLTF J-Surround
Flat Progressive Rate Nomex® Damper
with Spiral-Woven Leads
8-Gauge Lug-Lock Input & Output Terminals
Rated at 2200 Watts RMS
93dB Efficiency
Frequency Response of 45Hz to 900Hz
200 oz. Triple-Stacked Magnet
Dual 2-ohm 3” Voice Coils
Mounting Dimensions
Depth: 11 3/8”
Through Hole: 10 3/4”
Diameter: 11 1/4”
JLw713 this is a 13
Free Air Resonance (Fs): 23.5 Hz
Electrical “Q” (Qes): 0.476
Mechanical “Q” (Qms): 7.517
Total Speaker “Q” (Qts): 0.448
Equivalent Compliance (Vas): 3.68 cu. ft. / 104.3 liters
One-Way, Linear Excursion (Xmax)*: 1.25 in. / 32 mm
Reference Efficiency (no): 0.269%
Efficiency (1W/1m)**: 86.3 dB SPL
Effective Piston Area (Sd): 107.35 sq. in. / 0.0693 sq. m
DC Resistance (Re): 2.41 ohm***
Nominal Impedance (Znom): Dual 1.5 ohm
Thermal Power Handling (Pt): 1000W
Driver Displacement: 0.21 cu. ft. / 5.9 liters
Net Weight: 52 lbs. / 23.6 kg
man thats a comparison i can say i have never seen...JL vs Alphasonik....
im not a jl fan but in this case i think jl al the way !!! for the guy who told that here we are to recomend kicker, re or fi, that depends for the aplication....if you want a sq sub its probably that jl works for it..but if you want tons of pressure, maybe some RE or FI sub will be the best....
lol thanks i thought so this guy in the audio shop tryed to **** me with the alpha saying there better i was going with the jl but just wanted to make sure before i brought it thanks guys im getting the w7
mustangmoe
mustangmoe
staten island n.y
mustangmoe
vegang
vegang
