jl audio w6
Big Reazon
Right now I have 4 jl audio w6 10s. I plan on putting for of them in my el Camino. I have a couple questions. How much space net should I give to each sub. I want to tune them to 32hertz. SO how much net should I give them. How much port space. Should I go with the normal 16square inches per cubic foot. I cant really afford to have port noise. Also these subs are dual 6 ohms at 300 watts rms. What can I use to power them? If this matters I like big boomey bass if that affects port size but I want to have my double kickbass.
from my understanding if you use all 4 on 1 amp you can only wire them to 3 or 12 ohms. If you use 2 amps u can wire to 1.5ohm or 6 ohms. me personally, I'd use a JL 1000/1 amp as they are 1.5-4 ohm stable for atleast 1000 watts rms, but there may be a better amp out there for you.
No these arent the v2s they are the original ones. Jl says I can run the gor of them at .75 or 3 ohms. The subs ask for 300 watts rms but I know they can take a pit more. So what is a good amp to use. I was looking at the saz 1500 but I don't like the fact that there is no warranty under 1 ohm any more.
Big Reazon
Big Reazon
Seattle, WA
Big Reazon
vegang
vegang
