Sold JL & memphis amp, NIB eDi 6000 v.2
used JL e1400D. the person i bought the amp off of didnt have the screws so i used screws that were in my garage
Rated Power:
240 W RMS x 1 @ 4 ohm (12.5V);
400 W RMS x 1 @ 2 ohm (12.5V)
THD at Rated Power:
S/N Ratio:
>95 dB referred to rated power (A-weighted, 20 Hz ヨ 20 kHz noise bandwidth)
Frequency Response:
10 Hz ヨ 25 kHz (+0, -1dB)
Damping Factor:
>500 @ 4 ohm / 50 Hz
>250 @ 2 ohm / 50 Hz
Input Range:
200mV ヨ 8V RMS
Dimensions:
11.81" x 9.25" x 2.36"
Features:
High-Damping Class D Circuit with discrete control circuitry (U.S. Patent #6,441,685)
Differential-Balanced Input Topology:
RCA jack inputs (low-level) and multi-pin jack (high-level)
On-board Crossover:
Fully-variable (40-200 Hz), selectable slope Low-Pass (12 or 24 dB / octave)
Preamp Output:
Pass-through type.
Bass EQ :
+6db fixed frequency, fixed 'Q' (defeatable) with port for optional remote bass control (RBC-1).
Dual mono speaker output connections:
accept up to 8 AWG wire
+12V and Ground connections:
accept up to 4 AWG wire
looking for around $135 +4% paypal
slappinX
throw your diamond in air
slappinX
Bay Area, CA/SJSU
ViolentAudio
