jl 13w7 jl 1000/1
ok finally got it hooked up and the used amp I bought does not power on. Do these amps have internal fuses? The amp/sub I pulled out worked fine.
it would be .75 ohm series, so u wouldn't actually be able to run it with that amp. it's not stable that low. but make sure u have good grounds and whatnot
yea I wired it in series so I should be good to go. The grounds and all are good as they were in use minutes before hooking up the 1000/1.. I was trying to get it all done tonight as its my son's BD present.
the remote wire is hooked up not sure what voltage I am getting. Is there a link that shows how to test that as I have a volt meter.
ok I will do that. The other amp works fine though I re installed the other one and back to normal. Its like the JL has no power as non of the lights lite up either on the amp not a one.
I am going to take it into a local shop tomorrow and see if they can test it out for me.
Thanks all, Jeff
gqjeff
Waz up????
gqjeff
IL
KHARPS
